May 18, 2005, 03:35 |
3CPU vs 2CPU
Hi, I prepared a Moving Mesh problem with UDF, and it runned well under 2 CPU. I wanted to try to run it under 3 CPU, but it failled as I import the *.cas file, here is the error message:
Hex-core Mesh: 27 encapsulated cells, 1140 parents, 4560 child faces Primitive Error At Node1: Cannot locate child -151743 in new face 1488190 I don't understand why it runs under 2 CPU and not under 3 CPU. Any idea? Thanks Maxime |
May 18, 2005, 04:12 |
Re: 3CPU vs 2CPU
i think the cure for this would eb this, u can read the mesh on single processor machine, and do the manual partioning for three processors, save the case data files and read them in three processor.
should work |
May 18, 2005, 04:18 |
Re: 3CPU vs 2CPU
Hi, Already tested, but doesn't work. It returns the same message
May 18, 2005, 04:27 |
Re: 3CPU vs 2CPU
ok it works, but I had to disable the Encapsulate Grid Interface toogle Thanks!!!
Help: Batch file for Parallel Processing ( 2CPU ) | SC | FLUENT | 1 | July 15, 2003 21:34 |
