May 24, 2005, 07:05 |
Convergence problem
Can anyone please tell me the techniques of getting a converged solution for unsteady, compressible turbulent flow with species transport.
Sincerely, Saad |
May 24, 2005, 11:13 |
Re: Convergence problem
You can use low under relaxation factors for the parameters that more divergence is observed. On option is to use low relaxation factor for first time steps/interations and then use high relaxation factor. Using low relaxation factor will slow your solution.
Regards |
May 27, 2005, 07:49 |
In the solution control panel , go to surface -- > residual . there u could find convergence resolution criteria of 0.001 will be ther u just change it to o.1 and run. Also u could reduce the moment value from default of 0.7 to o.2 as such in the solve,control options. thus u could bring the convergence
convergence problem when use pisoFoam, LES for wind tunnel case | Forrest_Lei | OpenFOAM | 3 | July 19, 2011 06:00 |
convergence problem | commonyue | Main CFD Forum | 1 | December 1, 2009 03:54 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 01:17 |
3D Fluid Flow Convergence problem | Emily | FLUENT | 2 | March 21, 2007 22:18 |
Non Convergence of 3D Heat transfer cfd problem | Balraj | Main CFD Forum | 3 | December 9, 2004 00:24 |
