compiled udf in windows
hi,
I need to build a compiled udf.I am using Windows XP operating system.The compiler that I am using is VC Toolkit. I have executed the vcvars32.bat from the command prompt. but still when I give the 'nmake' command,it says "'nmake' is not recognized as an internal or external command,operable program or batch file." how do I overcome the problem??? |
Re: compiled udf in windows
Have you set the Path to VC? Luca
How to do that? I have no idea.Can you help me out and tell me me how to set the paths?
Search on the net hot to set path in Windows you just have to rigth click on the main icon, choose property,choose advance,environment variable,then modify the PATH adding the directory where VC is. Luca
Help me please, i would like to compile udf in Windows. Thank you in advance |
