About mixture model
Old   June 2, 2005, 23:02
Default About mixture model
fpingqian
I want to simulate the gas-solid flow in a cyclone seaprator by means of the mixture model in Fluent.In my work, the inlet particle size accords with R-R distribution. At the other hand, in mixture model, we only can give one particle size. Therefore, I want to consider the different particle size by adding the number of the phase,i.e. phase 1 is 1 micron, and phase 2 is 5 micron, and so on. I don't know if this method can satisfy my need. Hope someone who has the experiences in this can help me. Thanks in advance.
Old   June 7, 2005, 05:42
Default Re: About mixture model
Aly
Just a thought! why not use Eulerian multiphase model? and use UDF for different particle size distribtuion?
Old   June 7, 2005, 07:42
fpingqian
Thanks for Aly's response. In my mind Eulerian multiphase model, we could not use for different particle size distribution which is the same as the mixture model.
Fluent's Mixture model in CFX FLuentSwitch CFX 14 December 27, 2014 09:15
A question about UDF utility in mixture and multiphase model aleisia Fluent UDF and Scheme Programming 0 June 7, 2011 16:32
species transport model or mixture model?HELP zhhjll FLUENT 3 March 5, 2011 15:27
Mixture model for Multiphase flows sandisk FLUENT 0 January 23, 2011 18:05
MULTIPHASE - FREE SURFACE & MIXTURE MODEL Aris FLUENT 3 April 28, 2009 11:46
