hydraulic diameter
Old   June 20, 2005, 06:37
Default hydraulic diameter
David
I would like to know I'm using a periodic boundary condition so 1/10 of my cylinder is represented. By setting the turbulence parameters, do I need to set my hydraulic diameter to 1/10th of the full geometry or the full diameter itself?
thank you
David
Old   June 20, 2005, 12:31
Default Re: hydraulic diameter
Evan Rosenbaum
Full Diameter
Old   June 21, 2005, 03:54
manolito
Could you explain why to use full diameter?
Thank you in advance
Old   June 21, 2005, 12:19
Evan Rosenbaum
FLUENT needs to have the hydraulic diameter to get an estimate of turbulent intensity. The size of the eddies is limited to the physical space available, and hydraulic diameter is a representative value.
Old   June 22, 2005, 04:20
manolito
I got it. Thanks
Hydraulic Diameter - Series of Holes Jop FLUENT 6 January 14, 2019 09:41
equivalent diameter vs hydraulic diameter swamysrikanth FLUENT 1 October 12, 2013 01:18
[GAMBIT] hydraulic diameter? Zweeper ANSYS Meshing & Geometry 6 January 4, 2010 00:44
hydraulic diameter in 2d ahsan FLUENT 2 August 28, 2009 15:22
Importance of Hydraulic Diameter Value for Compressible Flow RyGuy FLUENT 0 August 6, 2009 10:58
