UDF, Looping through threads or faces
Old   June 20, 2005, 13:35
Default UDF, Looping through threads or faces
Zhang
Suppose I saved a UDM (User Defined Memory) variable in each face. Then I loop over the threads and faces to find the minimal of that variable: thread_loop_f(t, domain) {
begin_f_loop(f, t)
/* find and record the thread and face where the minimal exists */
tt = t;
ff = f;
end_f_loop(f,t) }
Here tt and ff are the same type as t and f, respectively. I am trying to use tt and ff to record the interested face and want to use them out of the loop. But it did not work. Is it because that "Thread *" and "face_t" are not like Integer of Real and they can not be assigned to another variable directly? Anybody has done similar thing and any suggestion? Thanks,
Zhang
Old   June 21, 2005, 01:24
Default Re: UDF, Looping through threads or faces
Joey
Can you do what you want within the loop using the "if........else"? I have not faced such problems. Can user define a global variables in UDF or just a UDF "global" variables.? I'm interesting in it. Could you email to me and tell me something detail?
Joey
Loop over the faces of a cell in UDF Anthony Wachs Fluent UDF and Scheme Programming 6 April 2, 2024 10:10
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 07:37
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
DEFINE_DPM_OUTPUT macro UDF HELP Puneet FLUENT 3 November 28, 2003 10:55
