running gambit
Old   June 24, 2005, 03:05
Default running gambit
sujeet
hi i tried to install fluent6.0 on win 2000.whenever i run gambit i get message "unable to open display". but same installation process on win XP does not have any problem.
Old   June 24, 2005, 10:38
Default Re: running gambit
Bikash Mishra
I get the same message, but if you let it run, GAMBIT opens eventually. If not try removing the old default_id files and GAMBIT folder created in your run directory. It might also be your Xclient installation.
[GAMBIT] Canīt start GAMBIT zalho ANSYS Meshing & Geometry 18 April 8, 2019 01:05
[GAMBIT] Close Gambit L3munoz ANSYS Meshing & Geometry 0 September 18, 2010 06:39
Gambit 2.3.16, Xming or Exceed...HELP! bambam3417 FLUENT 10 May 7, 2010 12:39
Athlon 64 Gambit Compatibility? Derick FLUENT 3 January 17, 2006 17:28
Generating big meshes with GAMBIT on NT Andrew Ooi FLUENT 12 February 2, 2000 22:26
