June 28, 2005, 21:16 |
error using Fieldview to read fluent result
Dear all,
i try to read the fluent particle result (part report) to fieldview. I use the translator in Fieldview CD, fluent2fvp_pc.exe. However, after import to fieldview, a error occured: Line ****** Char-1 : Excepting path tag ID. The Line ***** is the last line of the fvp file and it's blank. |
June 29, 2005, 06:56 |
Re: error using Fieldview to read fluent result
The problem is that the fieldview translator is now obsolete. you can export directly to .fvp format from fluent 6.2 under the solve -> particle history -> export particle data.
You can also fix that error in your files using another method. Open the .fvp file in text editor and you should see something like this Variable Names 9 TIME U-VELOCITY V-VELOCITY W-VELOCITY DIAMETER TEMPERATURE DENSITY MASS The problem is that there is supposed to be 9 tag names in this example, however there is only 8. Simply add another tag name, such as COLORBY to the list and save the file. This should fix the error |
Parallel Error in ANSYS FLUENT 12 | zeusxx | FLUENT | 25 | July 17, 2015 04:40 |
Fluent jobs through pbs | ibnkureshi | FLUENT | 5 | June 9, 2011 13:43 |
Fluent Result | interawe | FLUENT | 2 | March 21, 2009 13:36 |
FLUENT - Fieldview | tom | FLUENT | 2 | August 22, 2007 08:36 |
Comparing Fluent Time dependent result with Patran | venigall | FLUENT | 0 | January 13, 2007 19:30 |
