Fluent : Hydraulic Diameter < 1mm ok???
Old   July 4, 2005, 05:35
Default Fluent : Hydraulic Diameter < 1mm ok???
jerome-gmc
I'd like to simulate a biphasic flow in micro-channels (hydraulic diameter < 1mm). I'd like to check the internal pressure drop and the heat exchange coefficient in the channels. Is Fluent 6.1 able to simulate this properly??
Thanx a lot, Jerome
Abaqus - Fluent Coupling WITHOUT MPCCI s.mishra FLUENT 1 April 5, 2016 06:47
What the differences flow equation of Fluent 6.3 and Fluent 12.1 opehterinar81 FLUENT 0 August 19, 2011 11:55
Master node in parallel computing only distirubtion syadgar FLUENT 1 September 8, 2009 16:41
On Bug of Fluent 12.0 lzgwhy FLUENT 0 August 26, 2009 06:41
What is hydraulic diameter and reference value? vincent FLUENT 1 October 1, 2007 09:59
