non-positive surface area
Old   July 3, 2005, 23:57
Default non-positive surface area
vengi
Hai guys!
While meshing in gambit, there is no grid problem as I checked in face mesh-check. But in fluent, while grid checking, it failed due to non-positive area, Even after refining the grid.
Please help me to eradicate the problem.
Old   July 4, 2005, 01:06
Default Re: non-positive surface area
Balaji
i)Are you using axissymmetric.If so the axis has to be parrel to X axis and all grid should be positive X axis. ii)Check the skewness of grid in gambit.If this is more than 0.9 better remesh this.
good luck
Old   July 4, 2005, 02:40
vengi
Thanks Balaji,
But I am not axisymmetric. As well, my max skew is 0.8493.
Vengi
Old   July 19, 2005, 09:52
ayyappan
then what is your problem define it corectly
Non overlap area fractions saisanthoshm88 CFX 11 September 17, 2015 18:42
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
[snappyHexMesh] Add additional boundary layers to complex stl surface tobijingles OpenFOAM Meshing & Mesh Conversion 1 October 26, 2011 10:45
Storing Surface Area of each cell in a file? Markus Alzon FLUENT 0 June 21, 2007 08:38
Compute total surface area of Dpm figo FLUENT 0 September 8, 2004 21:44
