spawn problem
Old   July 4, 2005, 10:22
Default spawn problem
michel
I am having problems in parallel processing in that i cannot spawn nodes on other machines.
I can ping other machines, fluent recognises other computers IP adresses. I am using rshd for communication. Fluent.Inc directory is shared.
Looking forward to hear from you
Old   July 5, 2005, 08:37
Default Re: spawn problem
Mahesh
check for 1) whether fluent.inc directory is same or not. 2) try Using same login. 3) License
Old   July 5, 2005, 09:01
K. Jagus
Where do I set up login and what exactly login should I use?
Old   July 6, 2005, 10:31
Steve
Try the following address for instructions:
www.FLUENT.com/support/installation/winfaq/mpich.htm
Also, the following link is a brief Q&A:
http://www.fluent.com/about/news/new...pdfs/nl417.pdf
I recommend the MPI versus the RSHD. I was not able to get the RSHD to work. The MPI worked first time.
Hope this helps.
Steve
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
