Fluent pipe bends problem
Old   July 10, 2005, 17:28
Default Fluent pipe bends problem
Sandy
I am trying to model water flow in a pipe that has two bends, one of them is out of plane. The pipe length is 10 diameter long, followed by a 90deg bend with 3 diameter radius of curvature. Then followed by 10 diameter straight pipe, then a 90deg bend followed by 30 diameter straight pipe. Re=3*10^7, pipe diameter=0.7m inlet velocity 6m/s Pressure: 8000,000Pa Materials: water Can anyone give me some advice on the following? I appreciate all your inputs. Thanks! 1. Should I use LES for the viscosity setting? 2. Solver: Steady or Unsteady (1st order? 2nd order?)?? 3. What mesh size should I use if I want to use the adaptive mesh method, and the y+ needs to be 1? 4. Segregated or coupled? 5. What time step size and number of time step should I use?
Fluent - license problem. Marcin FLUENT 3 April 13, 2018 16:33
MPI problem with fluent aryanet FLUENT 17 October 30, 2017 21:04
Problem about Fluent on Linux hbinma FLUENT 3 July 6, 2008 10:49
UDF problem caused by various version of Fluent Yurong FLUENT 3 January 15, 2006 10:57
Licensing problem with Fluent v5.5 moiami FLUENT 3 April 17, 2002 03:50
