July 12, 2005, 12:50 |
HELP how to simulate my problem?
Hello, Could you please tell me how to simulate this following problem: I have a tube(100mm) full of oil at 8bars, on the left side the tube is closed by a wall which is hooked to a spring(so the wall can move), on the right side there is a winnow, and behind this winnow there is oil at 20bars. I want to open the winnow and see the movement of the wall with the spring until pression is stabilize to 20bars.The problem is that there is not really a flow of oil, the oil at 20bars "push" the oil at 8bars until the pression is stabilized. Please, what is the good configuration of simulation for this problem? because I find values completly false. Thanks,regards
Need any WHATEVER Help,please. Heat-Flow problem | Amr | FLUENT | 1 | March 15, 2013 11:47 |
Problem Importing Geometry ProE to CFX | fatb0y | CFX | 3 | January 14, 2012 19:42 |
Can I solve this problem by Fluent? | Kai_kc | FLUENT | 1 | October 27, 2010 05:29 |
Velocity profiles problem behind the elbow (3D problem) | kabat73 | FLUENT | 8 | May 9, 2010 04:26 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 14:52 |
