Multi materials in conduction
Old   July 19, 2005, 13:53
Default Multi materials in conduction
Fluent
Hi Guys,
Want to model conduction through coupled solids. i.e. solids that are in contact with each other yet have different material properties.
I assume this is possible in Fluent but would want a few bits of advice on how to go about it.
How do I connect the different regions so that conduction can occur across the connection? How do I set different material properties? Can I set a bond resistance for the juntion?
Ta
Old   July 20, 2005, 12:29
Default Re: Multi materials in conduction
Evan Rosenbaum
Make separate regions that share common edges in GAMBIT. Each region will be a different material. If you want contact or bond resistance, define the common edges as walls. In FLUENT you can then assign a thickness and conductivity to the walls.
Old   July 22, 2005, 06:08
Fluent
Thanks
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Heat conduction through Sand or pulverised materials dwqi0419 CFX 6 May 26, 2010 04:53
Heat conduction between contacting solid materials Ken Adams FLUENT 5 January 18, 2007 18:14
conduction happens in two types of materials lily FLUENT 2 April 20, 2006 10:52
