November 2, 2011, 14:54 |
Text command for report surface integral
jianbo jiang
Dear all,
I have a question about report surface integral. I have a large number of fluent case/dat results. I want to batch-process the results and get the surface integral of heat flux through the walls. For every cas/dat, the name of walls are different. In the menu "Reports", if "Fluxes" is considered, there is one option in the text command "all boundary/interior zones [yes]", so I can output the results for all the boundaries. But if I want to output "surface-integral" by text command, there is no such option to output all the boundaries. Theoretically, I can manually input the name of boundaries case by case in jou file, but the problem is that there is a large number of Fluent cases. Does anybody have the experience to output the surface-integral by jou file without inputting the name of boundaries beforehand? Thanks! best, jjb |
Display Modes | |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 06:41 |
How can be calculate a surface integral in the finite element method? | HectorRedal | Main CFD Forum | 3 | March 13, 2015 08:25 |
Calculating forces on a non-closed surface | ScottN | FLUENT | 0 | March 1, 2011 17:18 |
Surface Integral - Mass Flow Rate | Venkatesh V | FLUENT | 3 | October 10, 2008 16:18 |
Normal - Helical Surface | m. malik | Main CFD Forum | 3 | February 3, 2006 12:56 |
