how to define the external airflow b.c
Old   July 26, 2005, 03:13
Default how to define the external airflow b.c
frank
Dear all, how to define the external airflow boundary conditions, expecially for the outlet? since there is more than one free face? I set the velocity inlet as the inlet boundary condition. outflow as the outlet b.c.? How about the other free face? Could I give them pressure outlet? Could I mix use the pressure outlet and outflow in one case?
Thanks in advance
Old   July 26, 2005, 03:23
Default Re: how to define the external airflow b.c
Luca
Use the far-field bc on all your external bc. Luca
Old   July 26, 2005, 05:50
Default airflow b.c
frank
sorry, I did not mention that it is incompressible flow. therefore, the far field could not be used
Old   July 26, 2005, 09:57
Default Re: airflow b.c
Luca
Ah, oK. So you can use velocity inlet and pressure outlet.Let me know if I'm clear.Luca
CGNS Compiling Diego Main CFD Forum 17 December 21, 2014 01:40
Installing OF 1.6 on Mac OS X gschaider OpenFOAM Installation 129 June 19, 2010 09:23
Missing math.h header Travis FLUENT 4 January 15, 2009 11:48
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
UDF FOR UNSTEADY TIME STEP mayur FLUENT 3 August 9, 2006 10:19
