hyperthreading on intel P4 Prescott
Old   July 28, 2005, 06:28
Default hyperthreading on intel P4 Prescott
Cedric
I bought a new computer: INTELŪ PENTIUMŪ 4 PrescottŪ @ 3.2GHZ 800mhz FSB/HTT/1MB 2048 MB DDR400 PC3200 Motherboard: ASUS P4 S800-MX-SE
It actually runs Fluent nearly 15% slower than the laptop (1.6GHZ centrino, 750MB RAM) that I was using before.
Do you find it normal? When Fluent is running, only 50% of the CPU is used. It must be because of the Hyperthreading. Should i disable it?
Thanks for your help
Cedric
Old   July 28, 2005, 07:36
Default Re: hyperthreading on intel P4 Prescott
Mehdi Ghoddosy
Dear Cedric:
Sure, you have to disable hyperthreading. Also, try to set FLUENT priority to a higher level. For this press crtl+alt+ecs tp open task manager in windows. Then go ot processes tab, right click on fluent application and then set is priority high. This will utilize your CPU and RAM in maximumm range possible.
Best Regards
Mehdi Ghoddosy
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
Suitable Intel Fortran under OpenSuse 10.3 Christoph Meyer Siemens 12 December 3, 2007 00:54
Intel compiler for linux x86 marcus Siemens 1 November 9, 2006 16:43
AMD X2 & INTEL core 2 are compatible for parallel? nikolas FLUENT 0 October 5, 2006 06:49
64-bit processors for home computing Ananda Himansu Main CFD Forum 2 March 16, 2004 12:48
