July 28, 2005, 18:13 |
V2F Model
Hi all
Does anyone knows, how much does the licence for the V2F turbulence model cost? Regards, Maged P.S: I am a graduate student and I need this model for the research of my MSc thesis. |
July 29, 2005, 06:41 |
Re: V2F Model
Maybe you can a get free trial first, you should talk with your admin. We got one trial license (also at university) for three weeks, but V2F didn't work in my case.
July 29, 2005, 10:08 |
Re: V2F Model
Dear Dirk
Thank you so much for your help. Have you tried to use the V2F model for the Jet-in-crossflow case? (I have read your previous message about "LES of Jet in crossflow") I am also conducting numerical simulation of a Jet-in-crossflow, but I don't have enough computational resources to perform LES, so I will compare the results of different RANS models like standard k-e, SST, RSM and maybe also V2F with experimental results. I am using PC with 3 GB processor and 2 GB of RAM, so I think the use of LES or DES will not be practicable for my case. Your help and comments are highly appreciated. Maged |
July 29, 2005, 11:09 |
Re: V2F Model
That's right, I used it for a JICF. But my duct flow was laminar and so I wanted to simulate separation and transition around the exiting jet. V2F couldn't do this properly, the other turbulence models by the way couldn't either. But I didn't test V2F in fully turbulent flow.
Dirk |
July 29, 2005, 18:03 |
Re: V2F Model
I think you can do a les simulation for your case with about 2M cells (max). But it will be a little time consuming.
V2f turbulence model | qtian | OpenFOAM Running, Solving & CFD | 74 | January 15, 2018 07:19 |
V2f model , Fluent's background | pablo | FLUENT | 2 | July 11, 2016 16:32 |
LES and combustion model | Margherita Cadorin | CFX | 0 | October 29, 2008 05:24 |
v2f model in Fluent | Ramakumar | FLUENT | 0 | August 2, 2007 02:23 |
V2F turbulence model | Mark Render | Main CFD Forum | 8 | February 15, 2001 09:17 |
