multiphase flow-floating error
Old   July 29, 2005, 06:41
Default multiphase flow-floating error
masood
hi, i work on fluidized bed simulation,following error have been occured during the solution:
""Error: Floating point error: overflow"" what should i do?when this error occurs?
and following sentences:
""turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1745 cells turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1538 cells""
what should i do for that?is it a problem? regards
Old   July 29, 2005, 09:26
Default Re: multiphase flow-floating error
T.Hariharanath
hi masood,
in the panel solve-controls- limits set turbuelnt viscocity more than 10^5. for over flow problem u set pressure out let( bondary condition) to atmosphereic condition this may help u.
Old   July 30, 2005, 07:23
masood
Dear Hariharanath! i use pressure outlet with atmospheric condition but atill have this problem(overflow).it was steady state simulation ,now i turn on unsteady state and that problem dont exixst now! and is it true to change turbulent viscosity ratio limit?howmuch is real? regards
Old   July 31, 2005, 07:17
Swarup
Hi Masood,
you were right in switching to unsteady state. unsteady solution is better suited for highly non-linear problems. i would say that you should not change variable limits. they are set to optimum values and better left untouched.
Swarup.
c++ libraries and solver compiling vaina74 OpenFOAM Installation 13 February 3, 2012 17:43
OpenFOAM install on Ubuntu Natty 11.04 bkubicek OpenFOAM 13 May 26, 2011 05:48
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 18:44
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 06:25
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
