August 4, 2005, 17:27 |
problem in 3d parabolic velocity profile
Hi, I keep getting a error whenever i interpret(SEGMENTATION VIOLATION) or compile (Error code 1)the following code for parabolic velocity profile. I'm pretty new to Fluent. So I'm not exacltly sure what is causing this problem. Can anyone kindly help me in this regard
/************************************************** ********************* vprofile.c UDF for specifying steady-state velocity profile boundary condition ************************************************** **********************/ #include "udf.h" DEFINE_PROFILE(inlet_x_velocity, thread, position) { real x[ND_ND]; real r; face_t f; begin_f_loop(f, thread) { F_CENTROID(x,f,thread); r = sqrt(pow(x[0],2)+pow(x[1],2)); F_PROFILE(f, thread, position) = 2*0.1(1-pow(r/0.000175,2)); } end_f_loop(f, thread) } |
August 5, 2005, 06:42 |
Re: problem in 3d parabolic velocity profile
pow is not working , use x*x instead of pow(x,2).
August 5, 2005, 06:58 |
thanks a lot mahesh...i will check it out
August 5, 2005, 07:59 |
"pow" does work, I also use it.
August 5, 2005, 12:35 |
Hi everyone. I replaced the pow and even replaced the sqrt. But still the code doesnt work. It just gives me a message " Error code 1" if i try to compile it. Any help would be really appreciated. I have copied the code below
/************************************************** ********************* vprofile.c UDF for specifying steady-state velocity profile boundary condition ************************************************** **********************/ #include "udf.h" DEFINE_PROFILE(inlet_x_velocity, thread, position) { float x[ND_ND]; /* this will hold the position vector */ float r; face_t f; begin_f_loop(f, thread) { F_CENTROID(x,f,thread); r = (((x[0]*x[0])+(x[1]*x[1])))^0.5; F_PROFILE(f, thread, position) = 2*0.1(1-((r/0.000175)*(r/0.000175))); } end_f_loop(f, thread) } |
August 8, 2005, 09:54 |
obviously you forgot a "*" in the line with F_PROFILE() on the right hand side before the first bracket. I just tested this corrected UDF and it works. Dirk |
August 8, 2005, 16:21 |
it still doesnt work for me..do i have to do something else for building the library. i just compile my udf after reading my .cas file. Thanks Lokesh
August 8, 2005, 16:31 |
I used interpreted udf.
August 11, 2005, 05:36 |
#9 |
use interpreted udf also a multiplier is missing after 0.1
Display Modes | |
Parabolic inlet velocity profile | msrinath80 | OpenFOAM Running, Solving & CFD | 157 | February 6, 2020 05:13 |
3D UDF Paraboilc Velocity Profile with max velocity | johnGo | Fluent UDF and Scheme Programming | 1 | January 4, 2011 21:45 |
[boundary condition] logarithmic velocity profile | cfdworker | FLUENT | 2 | April 17, 2009 23:36 |
2D air parabolic velocity profile | ilker | FLUENT | 2 | November 12, 2008 08:43 |
Multi step transient UDF velocity profile problem | William177 | FLUENT | 1 | February 3, 2008 06:47 |
