axis change in fluent
Old   August 19, 2005, 13:05
Default axis change in fluent
Aly
Is there any option in fluent to change the reference axis of the geometry? like making a vertical pipe (y=height, x=z= radius) horizontal i.e changing y axis as x axis and making x as y.
Old   August 19, 2005, 13:50
Default Re: axis change in fluent
Anindya
You can do that under Display, by rotating the geometry.
Old   August 20, 2005, 17:15
Aly
Hi Anindya
i found the rotate option in transform surface bit could not do it after trying many times.
can u plz tell me how to rotate the vertical geometry (y axis ) to horizontal (x axis).
thanks.
Unsteady Boundary Profile with data file Arianna FLUENT 34 July 29, 2019 16:35
few quesions on ANSYS ICEMCFD and FLUENT Prakash.Paudel ANSYS 0 August 12, 2010 12:07
Master node in parallel computing only distirubtion syadgar FLUENT 1 September 8, 2009 16:41
On Bug of Fluent 12.0 lzgwhy FLUENT 0 August 26, 2009 06:41
How to change the material database for Fluent sxf FLUENT 1 May 3, 2005 16:37
