mAx
August 24, 2005 09:45 |
Y+
Hi, I'm working with CFD for computing pressure drop in hydraulic valves. I don't really check my y+ values as I solve problems, because predictions are in good agreement. But since weeks, I try to understand a difference between pressure drop computed by Fluent with the one computed with simple formula. As I checked my y+, I saw that they were less than 30 while using k-epsilon model with standard wall functions. The only way to reach the 30 y+-value should to generate a coarser mesh. But according that I am in millimeter domain, and I have to solve tiny opening, I can't generate coarser mesh, else I would have gap with just 1 cell in the section. So normally, I should refine and enable the enhanced wall treatment options of the k-epsilon model. But that means, I am condemned to work only with enhanced option. Does anybody have the same problem or is there anybody who is working in hydraulics with components in millimeter-domain. Thanks Maxime
