Handling boundary condition in Fluent
Hi Fluent users, i have a question, like in the geometry the periodicity between the boundaries is a mixed type of translation and rotation.
the boundaries are periodic but in fluent while dealing with boundary conditions, i cant select the boundary as both translation and rotation. any idea as how to handle the conditions if the periodicity is both translation and rotation. thanks in advance |
1 Attachment(s)
I am intresting this problem too) My mesh in this image SWIRL_STABE.jpg Do anyone have ideas how create both translation and rotation periodic in fluent? Thanks Alex. |
I think you could write a UDF about mesh motion that has both rotation and translation. This along with options about 'mesh motion' in 'Cell Zone Condition' should resolve your problem.
Total pressure at the outlet is more than inlet
hi
I am doing 3d modelling of a can combustor using k-e model.If I give mass flow inlet and pressure outlet or pressure inlet and pressure outlet I am getting total pressure at the outlet is more than total pressure at inlet.But there should be a pressure drop in reality in a combustor.Can u help:confused:? |
Pls check the location / methods (massflow weighted\area weighted average).
# what is inlet mach number (assuming subsonic) # what are teh values of To,Ptot inlet To,Ptot outlet values # what is the Ps in and out |
Its subsonic and pin=200000 and pout=212000 and the case is running well and giving results but in reality there should be pressure loss and here pressure is increasing..lets consider cold flow T=300k.In both cold flow and hot flow total pressure is increasing..
Hi Vasava!
Thanks for you reply! But I am some questions about this problem Is it better to use: mesh motion or frame motion in my case? And how I am can set velocity (translation and rotation) mooved mesh or referense frame? Constants? |
