August 18, 2020, 23:13 |
Convection Problem
Rep Power: 5 |
Hi all,
I'm working with a simulation of a Clusius-Dickel column, which use thermodiffusion and convection to separate the components of a gas mixture. In this type of column one has two concentric cilindres, one at higher temperature to create a temperature gradient along the radial direction. Usually the lighter component of the mixture agglomerate in the hot wall and the heavier in the cold wall. Then, due to convection the hot gas near the wall (in this case H2) goes up and the cold gas go down, generating a concentration gradient along the vertical axis. Unfortunately when I run the simulation the convection currents generated doesn't move the agglomerate species, they stay attached to the walls without movement. I don't understand why this happen; if someone could help me with some insight to the problem I would really appreciate it. I attached some photos. Fig 1 is a scheme of the Clusius-Dickel column. Fig 2 shows the enrichment distribution (%) of molecular hydrogen. Fig 3 shows velocity vectors created by convection. Kind Regards, KsaMe |
Display Modes | |
SU2-7.0.1 on ubuntu 18.04 | hyunko | SU2 Installation | 7 | March 16, 2020 05:37 |
interfoam: a problem with removing convection in the air phase | bieshuxuhe | OpenFOAM | 0 | March 31, 2014 23:56 |
Problem to simulate conduction and convection in the same time in FLUENT | zomayabssa | FLUENT | 0 | March 1, 2014 23:33 |
natural convection problem | samantasubho | FLUENT | 0 | October 6, 2010 11:07 |
ON TURBULET MODEL FOR A NATURAL CONVECTION PROBLEM | varghese | FLUENT | 6 | February 6, 2002 06:23 |
