Filter modeling problem
Old   September 13, 2005, 15:05
Default Filter modeling problem
Nishant
Dear Friends, I have problem where I am trying to model a box-like domain with one inlet and one outlet at opposite ends at top. The box is rectangular in shape. I know that the static or gauge pressure is 50 pa inside the box. The air outside the box is at ambient pressure. Also, just below inlet and outlet, there are filter boundaries. I have a couple of questions regarding this problem:
1. What will be correct way to specify the filter properties and inlet/outlet boundary conditions?
2. What kind of filter model can be used for such a problem?
Your help with this will be much appreciated.
Many thanks,
Old   September 15, 2005, 12:33
Default Re: Filter modeling problem
Evan Rosenbaum
Thin filter = porous jump. Thick filter = porous medium. (check the manuals)
Old   September 15, 2005, 12:41
Nishant
Thanks Evan, Filter is about 3 inches thick so perhaps using the porous medium would be the right approach. Nishant
problem in modeling fluid-solid-fliud reem FLUENT 12 June 10, 2018 05:37
Aeroacoustic Problem (Modeling Flow-Induced Noise Problems Using FLUENT) cici Main CFD Forum 0 September 29, 2011 14:28
Problem in modeling membrane gas separation hakim22 FLUENT 0 July 31, 2011 10:28
Problem in modeling solidification S. Balasubramanyam CFX 0 January 20, 2004 09:54
problem with RSM modeling cwflying FLUENT 4 April 18, 2002 06:45
