Re: Dynamic meshing
Old   September 14, 2005, 19:52
Default Re: Dynamic meshing
avant
Hello Experts,
I am new to Fluent and am trying to model the eccentric motion of a solid body in a fluid medium. A solid cylinder is rotating around its axis. But the cylinder's axis is offset from the whole domain's axis. The solid cylinder is immersed in a fluid domain. (eg. a shaft rotating within a pipe). It would be very helpful if someone can describe how i should proceed regarding setting up the problem. So far, i created 2 mesh files (one for the fluid and one for the solid domain) and integrated them, assigned a sliding interface between the fluid and the shaft. But i have no idea how to define the dynamic mesh zone parameters. Please help. Thanks, Avant
dynamic meshing pronik_zoro ANSYS Meshing & Geometry 0 March 12, 2011 11:01
Dynamic meshing Manoj Kumar FLUENT 3 June 27, 2010 19:26
[GAMBIT] Dynamic Meshing of a combustion chamber donarundas ANSYS Meshing & Geometry 1 December 2, 2009 07:13
Issues with dynamic meshing sridhu88 FLUENT 1 June 11, 2009 16:46
dynamic meshing option arehman Main CFD Forum 4 June 27, 2004 02:55
