September 16, 2005, 05:37 |
Pressure coefficient plots...
When running an analysis of an airfoil, i am getting Cp values greater than 1, even after referencing the inlet velocity and setting the operating pressure to zero. Does anyone have any advice on how to solve this?
Thankyou all |
September 16, 2005, 05:44 |
Re: Pressure coefficient plots...
same old question and same old answer, refine the meshes near to the walls of airfoil. Cp values depend on the pressure gradients very much so if you can resolve pressure gradient nicely near the walls , you can get good values of Cp
high CPU load with no computation going on & Pressure coefficient output problem | spetsnaz26 | FLUENT | 0 | September 30, 2011 05:25 |
Pressure Coefficient Viscous Coefficient | gunposer | FLUENT | 0 | June 15, 2009 07:10 |
XY plotting pressure coefficient on the wall | Yucel Ozmen | FLUENT | 2 | January 16, 2006 21:36 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
Problem in Result of the pressure coefficient | Ken Choi | Main CFD Forum | 2 | March 15, 1999 04:15 |
