Modeling engine effects
Old   September 14, 2005, 11:41
Default Modeling engine effects
Riaan
My question is about modeling the effect of a gas turbine on the flow through an intake duct.
I have an intake duct, turbine and exhaust duct in a standard configuration:
Intake Duct volume --> Boundary Condition Face --> Turbine Volume (empty, not meshed) --> Boundary Condition Face --> Exhaust Duct volume
What B.C should I use at the end of the Intake duct volume - I know the massflow that the turbine requires, but not the Static Pressure or Total Pressure at this face.
What B.C for the inlet face of the Exhaust Duct?
-Thanks Riaan
Old   September 15, 2005, 03:20
Default Re: Modeling engine effects
Razvan
Do you want to MODEL the turbine, not actually calculate it (I mean you do not want to insert real turbine geometry in the middle volume and take its effects into account by simply imposing BC on the two faces)?
Razvan
Old   September 15, 2005, 07:44
Riaan
No, I don't want to model the turbine, just have a "black box" with inlet and exit b.c. similar to what a turbine would generate.
Old   September 15, 2005, 14:00
Razvan
Let me explain myself:
- MODELING = taking into account the possible effects of a certain geometry by analitical means, approximating it with a mathematical model, actually deliberately imposing not calculating its properties;
- SIMULATING = considering real geometry, calculating effects by imposing conditions on boundaries away from actual object.
So, what you're trying to do is MODEL the turbine, not SIMULATE it!
Concerning your problem, the only way I can imagine solving it is this:
- eliminate first and second volume and keep only exhaust pipe with turbine exit as inlet condition
- calculate by hand or using a mathematical program the radial distribution of fluid's thermodynamic properties based on specific turbomachinery relations
- input these radial profiles as BC at the inlet boundary
- obtain solution. Of course, you will have to repeat steps 2-4 for every mass flow you need to consider.
Best wishes, Razvan
Old   September 19, 2005, 08:24
Riaan
Found easier way. Set Mass-flow inlet B.C. at the turbine inlet face, with the mass-flow vector pointing "into" the turbine. Since this is a subsonic case, pressure values on the b.c. face will be interpolated from the cells next to the b.c.
Anycase, agree on difference between modeling and simulating. Quick and dirty forum post - sorry.
Old   September 20, 2005, 17:45
Riaan
Running into problems - seems the Mass-flow inlet creates a local strong shock in the exit plane...M>2...don't know why yet?
Modeling Hyrogen Sealing in an internal combustion Engine anatoliafire Main CFD Forum 0 May 3, 2010 02:40
Intrenal combustion engine (CI) modeling Majid FLUENT 0 August 2, 2009 09:04
Problems modeling subsonic engine air inlet with flow separation TWaung CFX 2 March 29, 2009 18:42
I.C. Engine Modeling Abdel-Fattah M. Mahrous Siemens 1 April 23, 2005 01:13
1-D Engine Network Modeling Zamir Main CFD Forum 10 November 24, 2004 03:18
