June 8, 2012, 16:47 |
VAWT simulation
Teaching assistant and research engineer
Hey all
Basically i am working on darrius turbine (VAWT) Which is composed of a rotating domain slightly greater than the turbine radius and stationary domain around the rotating one working with omega =25 rad/sec wind speed =5 m/sec the following is the steps of solution 1- PB/transient 2-realizable k-epsilon 3-cell zone the i gave the internal domain mesh motion with 25 rad/sec 4-BC ....gave the blades rotational speed zero relative to moving domain ...setup inlet velocity 5 m/sec.....select the edges of moving and stationary domains to be interface instead of wall 5-creat mesh interface between edges of moving and stationary domains then complete the normal steps after finishing i found the Cm to be very high can any one tell me what i should do more to get the right solution please |
Why my simulation not agree with the wind tunnel experiment | zhaowei | CFX | 4 | July 11, 2015 03:36 |
Solar Radiation in OpenFOAM | plainstyle | OpenFOAM Running, Solving & CFD | 15 | July 8, 2014 04:43 |
Simulation of a complex wing in solidworks flow simulation | niels1900 | FloEFD, FloWorks & FloTHERM | 6 | April 20, 2011 10:44 |
Continuous vs interrupted simulation | sega | OpenFOAM Running, Solving & CFD | 4 | November 3, 2008 14:29 |
strange simulation error | Ralf Schmidt | FLUENT | 2 | May 4, 2007 13:02 |
