Y+ and accuracy of Pressure Coefficient of a wing |
October 3, 2005, 19:30 |
Hi All,
Forgot to ask a question in my previous thread. The 2D analysis I am doing here has a Y+ value of 2 (min) and 11 (max), however the S-A Turbulence model says that a Y+ of 30 should be used. Does it mean that the pressure coeff. are not right! or should I stick with the current value. The adapt option in Fluent doesnt seem to coarse the grid for Y+ of 30. Thanks in advance, Mick |
October 4, 2005, 09:15 |
Re: Y+ and accuracy of Pressure Coefficient of a w
Spallart-Almaras model is much better suited for y+=1. So adapt your mesh to this value. A value of y+=5-6 is very wrong (and I bet that's the medium value for your model)!
Observation: if you got a structured mesh, then coarsening is impossible (this is available only for unstructured meshes)!! Razvan |
October 4, 2005, 16:19 |
Hello Razwan,
Many Thanks for the reply. Yes you are right, I am using a structured grid close to the wing. According to your advice I adapted the mesh to Y+=1 by using min value=1 and max value=1. Correct me if I did it the wrong way. Now, when I plot the turbulence for wall Y+, I dont see any lines that are close to 1. It is in a region of about 5 and 12! What have I done wrong here? Many Thanks in advance. Mick |
October 4, 2005, 16:39 |
Use y+= (min(0.8),max(1.2)). It will not work otherway. Also, activate dinamic adaption, and set 10-20 iterations for adaption. This tehnique (adaption) is not so great after all, because it introduces a high gradient of cell volume right where it isn't needed: in the boundary layer! So, for better precision I use this type of adaption only in desperate cases. What you should try to do is to obtain a good grid right from the start. To do this, follow my instructions:
- make first a 2d grid for a flat plate, and calculate flow over this plate with BC for your final case (same velocity, temperature, pressure, etc) - plot y+ values on the plate: this way you will find out if you have chosen the right size for first cell at the wall; if you did not succeed at the first shot, try again until you figure out what cell size would be needed to obtain a desired y+ value - take this value and make a good grid for your final geometry. Best wishes, Razvan |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
Increasing the accuracy of pressure head values in output data | Saeed1390 | FLUENT | 0 | June 13, 2011 02:17 |
Finite Wing Simulation | Altocirrus | STAR-CCM+ | 1 | February 7, 2011 12:41 |
Intake Flow Simulation Accuracy | atlantis83 | FLUENT | 0 | April 25, 2010 05:18 |
negative static pressure !?! | Marat Hoshim | Main CFD Forum | 15 | October 26, 2000 11:48 |
