SUDDEN SPIKE
Old   October 6, 2005, 02:54
Default SUDDEN SPIKE
Jane
I am working on modelling the hydrodynamics of flow in a stirred tank reactor. The modeled reactor is an axial flow impeller type.
The size of my reactor is 0.3m(H=T) with impeller clearance of 0.1m. I made use of Multiple frame of reference modelling technqiue in which the impeller region is identified as the rotating block and the other part of the tank(baffles & rest)are stationary.I have run simulations with grid of 88,690, 174,000 and 270,000 structured cells.
Above the impeller region just immediately after the interface,i noticed a sudden spike in radial velocity and tangential velocity as i approach the shaft wall. This is really gave me a concern.
Can anyone advise on any clue to correct this abnormality?
Expecting yr reply
Meshing Sudden Contraction and Expansion carldaru ANSYS Meshing & Geometry 33 January 27, 2017 00:56
sudden drop in solver monitor jiguozhao CFX 3 February 27, 2011 05:34
Need help. plzz (Axisymmetric Sudden Expansion) ruzfactor Main CFD Forum 0 November 26, 2010 18:21
Sudden pressure change in overset Ben Main CFD Forum 6 July 21, 2007 19:46
sudden perturbations adarsh Main CFD Forum 0 June 11, 2002 12:08
