wrong dimensions when reading mesh file
Old   October 11, 2005, 22:47
Default wrong dimensions when reading mesh file
stella
hello, when i read my mesh file into fluent. its says file has wrong dimensions and could not read the file. Why is this so? I have not even scale the file or anything, only draw it out in gambit. many thanks.
Old   October 11, 2005, 22:56
Default Re: wrong dimensions when reading mesh file
stella
I think it is something I did wrong when I exported the file. So anyone who has this problem can check their gambit files. thks for reading.
Old   October 12, 2005, 05:42
RoM
Gambit by default exports a 3D mesh. If you want a 2D mesh you will have to activate the "Export 2-D(X-Y) Mesh" button.
RoM
Old   October 12, 2005, 12:30
Lam
Can you let us know the steps you did in order to export your mesh? Sometime the problem come from the quality of mesh itself.
paraview installation woes vex OpenFOAM Installation 15 January 30, 2011 07:11
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
OpenFOAM Install Script ljsh OpenFOAM Installation 82 October 12, 2009 11:47
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 11:46
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 04:26
