Sway Motion UDF?
Old   October 14, 2005, 12:51
Default Sway Motion UDF?
Brian
I am trying to do a simple sloshing problem but I'm a bit confused how to perform it. I would like to sway (oscillatory x-motion) a 2D box as so: x = Amplitude * sin(omega * time). The box center is at (0,0) for simplicity. I know the amplitude and omega. I just don't know how to perform this task in Fluent. Any suggestions would rock! Thanks all!
-Brian
Old   October 17, 2005, 01:39
Default Re: Sway Motion UDF?
Manoj Kumar
Hi Brian
You can do this by adding time varying momentum source to the momentum equation using following udf ...
#include "udf.h"
#define pie 3.141592654
DEFINE_SOURCE(cell_x_source, cell, thread, dS, eqn) { real source;
/* source term */
source =(-Amplitude)*pow((2*pie/time),2)*C_R(cell,thread)*sin((2*pie/time)*CURRENT_TIME);
/* derivative of source term w.r.t. x-velocity. */
dS[eqn] = 0.;
return source; }
You can also use a time varying gravity or a combination of these to simulate real problems.
Good luck
Manoj
Old   October 17, 2005, 01:51
Manoj Kumar
Source equation should be
source =(-Amplitude*density)*pow((2*pie/time),2)*C_R(cell,thread)*sin((2*pie/time)*CURRENT_TIME); (N/m3)
Old   October 17, 2005, 04:31
RoM
I think the first version of your source term was correct. Now you have density squared (from Amplitude*density and C_R(c,t)) which is wrong. Although you dont have to define pie, you can use M_PI instead.
Regards
RoM
Old   October 17, 2005, 05:51
Manoj Kumar
You are right.
Thanks Rom
Old   October 18, 2005, 16:27
Brian
Where I do input amplitude and omega ("time" in your example)? Do I define them in the UDF?
Old   October 18, 2005, 16:28
Brian
NEVERMIND! STUPID QUESTION!!!! HAHAHAHA!!
UDF problem: incorrect grid motion Fil FLUENT 5 December 19, 2020 09:16
Grid motion with UDF fivos Fluent UDF and Scheme Programming 5 June 30, 2018 08:50
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Fluent UDF Discontinuous Motion lequi7 Fluent UDF and Scheme Programming 2 November 3, 2011 23:18
UDF error CG Motion Alex FLUENT 0 March 22, 2006 17:40
