October 20, 2005, 20:32 |
Temperature specifications
I have a 2d mixing elbow. The geometry and dimensions are exactly those of that given in the GAMBIT tutorial. Now I have 2 streams of water (373K and 273K) at the two inlets. Both are at the same flowrates. How do I specify the temperatures in FLUENT? Which command do I use? The flow is laminar and incompressible.
Thanks in advance. Vidya |
October 24, 2005, 01:30 |
Re: Temperature specifications
Enable energy equation (define->models->energy) and define the temperature in the boundary conditions.
RoM |
Problem with zeroGradient wall BC for temperature - Total temperature loss | cboss | OpenFOAM | 12 | October 1, 2018 06:36 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
Bulk temperature Tf is obtained from total or static temperature? | NPU_conanxie | FLUENT | 0 | March 30, 2011 05:56 |
Different patch type specifications for velocity and temperature | ankgupta8um | OpenFOAM Running, Solving & CFD | 5 | December 31, 2010 10:57 |
High temperature methane+air | Peter | FLUENT | 5 | January 26, 2009 18:04 |
