Meshing flow field
Old   October 25, 2005, 09:55
Default Meshing flow field
Vidya Raja
Hi, I've a solid geometry imported as a STEP file from ProE. I exported it to GAMBIT, then created a cylinder and enclosed the geometry inside it. I then subtracted the volume of the solid from that of the cylinder to get the flow domain within and around the solid. Then to mesh the flow field, I directly meshed the subtracted volume without meshing either the edges or the faces. Is this correct? I tried following the hierarchy of GAMBIT- i.e., mesg edges, then faces, and finally the volume. But there was always some error and the program crashed. So I meshed the volume directly. I want to know if this is OK or will it cause problems after taking it to FLUENT?
Thanks, Vidya
Old   October 25, 2005, 13:39
Default Re: Meshing flow field
sam
if you successfully checked for meshed volume using quality commands and see no voids, you're alrite,
Old   October 25, 2005, 13:50
Vidya Raja
I checked the mesh using the EXAMINE MESH command and it showed that the two indicators (which indicate the quality of the mesh) were at the middle, so does that mean that the mesh is 50% ok? The mesh looked coarse though. It was triangular and the type was Pave.
Is this ok?
Thanks, Vidya
Old   October 25, 2005, 14:26
sam
NO, it just gives you the quality of your mesh in terms of the skew angle etc..., it means you have a mesh. A mesh is either existing and workable or its not, there;s nothing in between. A bad mesh could be workable as well. Read more on quality of mesh, its effects on the solution.
Porous domain in a flow field rikio CFX 7 August 25, 2009 22:39
initialize flow field with steady state solution holg FLUENT 0 July 13, 2009 17:10
flow field residuals into posdat? nicola Siemens 0 February 9, 2007 10:54
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 05:44
computation about flow around a yawed cone Tylor Xie Main CFD Forum 0 June 9, 1999 07:33
