DPM injection with RR distribution
Old   October 31, 2005, 15:03
Default DPM injection with RR distribution
dan
I'm running a coupled, discrete phase simulation with a surface injection and a RR particle diameter distribution. Once the simulation ran, I took a sample at a line parallel to the injection rake (axisymmetric problem). However, the histogram of the diameter distribution shows an uniform distribution of the number of particles. Since the mass flow of particles is bell shaped, an uniform diameter distribution was not expected. I've also tried creating multiple surfaces and specifying the diameter and the corresponding flow rate, but I still obtain a histogram with a uniform distribution.
If anyone has an idea what might be wrong, your response would be very much appreciated!
Thanks, Dan
Old   November 1, 2005, 05:05
Default Re: DPM injection with RR distribution
Henrik Ström
Hello!
Maybe this thread can shed some light:
http://www.cfd-online.com/Forum/flue...cgi?read=27795
/Henrik
Old   November 1, 2005, 09:29
dan
Thanks, that did help!
I really appreciate the help.
Dan
DPM diameter mass distribution Wouter FLUENT 5 May 23, 2019 02:18
On DPM injection properties. akr FLUENT 4 October 23, 2006 10:54
DPM, UDF, Injection Type Zhang FLUENT 0 June 8, 2005 15:51
Group injection distribution David FLUENT 3 October 14, 2004 20:01
DPM Injection Parameters Hendawi FLUENT 0 June 13, 2002 09:41
