interface
After initial the model, the system tells the following warn.
WARNING: Unassigned interface zone detected for interface 6 Error: Init_Flow: unassigned interface_zones Error Object: () What happen? How to change it? Thank you! |
Re: interface
If ur interface contain periodic surface; check on periodic in interface panel.......... If interface contain two different fluids or solid-fluid interface, plz check on coupled in interface panel. hope it will be helpful..........
