drawing curved line,plotting skin friction lines |
November 16, 2005, 20:50 |
I'm using Fluent 6.2. I'm trying to draw a line on the blade. I actually wanted to draw a curved line but in the function panel for creating line, only straight line can be drawn. May i know how to draw a curved line on a wall surface (which is curved)? I need to do that as i want to do a XY plot of the static pressure along that curved line on the blade.
I'm also trying to plot skin friction line on wall surfaces. In the function panel for plotting pathlines, i can only obtain the pathline but not the skin friction lines on wall surfaces. How do I do that in Fluent??? Regards |
November 17, 2005, 07:16 |
Re: drawing curved line,plotting skin friction lin
hi,
you can actually draw a curved line that follows the shape of an exesting surface at a certain position. To do so, you have to create an "iso-surface" (from the dropdown list in "surface"). Choose surface of constant "grid" (you can draw the line at a constant x or y or z value, according to your geometry or surface of interest location, you have to specify the value in the iso-value box). In the "from surface" box you have to select the surface around which you want to draw the curved line. Hope this helps. Thérèse. |
Skin Friction and Shockwave evaluate problem | mosessitio | FLUENT | 0 | May 21, 2011 03:21 |
Skin friction in fluent is wrong | syler3321 | FLUENT | 2 | March 24, 2011 08:05 |
Compute Skin friction coef by hand | Francois | FLUENT | 1 | February 10, 2006 06:21 |
drawing curved line,plotting skin friction lines | Alex | Main CFD Forum | 0 | November 16, 2005 20:52 |
Skin friction lines in CFX-Post?? | Louwrens | CFX | 6 | April 14, 2003 16:36 |
