Can not Iterate this UDF
Old   November 22, 2005, 02:05
Default Can not Iterate this UDF
mike
Hi every one . I want to define the turbulent viscosity then i define this code. It can interpreting but it cannot iterate. Please someone help me #include "udf.h"
DEFINE_TURBULENT_VISCOSITY(user_mu_t, c, t)
{ real mu_t; //TURBULENTVISCOSITY
real p = C_R(c,t); //density
real k = C_K(c,t); //Turbulent kinetic energy(k)
real e = C_D(c,t); //Dissipation rate (epsilon)
real Ret; //Turbulent Reynolds number
real u = C_MU_L(c,t); //laminar viscosity
real v;
real fmu; //Damping function
real cmu = 0.09;
v=u/p; //Kinenatic viscosity
Ret=k*k/(e*v);
fmu= exp(-6.0/((1.0+(Ret/50.0))*(1.0+(Ret/50.0))))*(1.0+(3.0*exp(-Ret/10.0))); //Damping function
mu_t =cmu*fmu*k*k/e;
return mu_t;
Best regard
Old   November 22, 2005, 15:17
Default Re: Can not Iterate this UDF
Zhang
I tested your code. It works well in my system. Windows XP, Fluent 6.1.22 and 6.2.16, 3-D geometry Both Intepreted and Compiled
Old   November 22, 2005, 21:57
mike
thank you very much Zhang. I used Fluent 6.1.22 with Win XP. This code Intepreted and Compiled but when I iterate the problem ( Channel Flow 2D) it is error. Thank you
Old   November 23, 2005, 19:26
Default What kind of error message?
Zhang
Did you hook this UDF?
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
HELP! Fluent UDF Iterate error Sam FLUENT 2 July 10, 2008 21:29
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 04:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 04:01
