results with parallel processing
Old   December 27, 2005, 05:57
Default results with parallel processing
Muhammad Shakaib
I am solving an unsteady problem using linux cluster at six nodes. For comparison I started the solution (first few iterations)using the cluster and then started the solution using single computer. There was some difference in the printed residual values. Is this usual or something wrong has happened.
Thanks
Parallel processing of OpenFOAM cases on multicore processor??? g.akbari OpenFOAM Running, Solving & CFD 31 November 1, 2017 09:25
Parallel Processing Set Up virgilhowardson FLUENT 1 May 11, 2009 00:54
parallel processing in numeca sheeev koomaar Fidelity CFD 1 August 18, 2006 02:35
Paradox in parallel processing Vagelis FLUENT 0 October 26, 2005 05:36
parallel processing Nurul Murad FLUENT 2 July 25, 2001 03:11
