December 10, 2009, 00:54 |
gambit problem
Achyut Takalkar
Rep Power: 16 |
hello everyone
i am working on fluidized bed i am not able to understand, how to define solid bed in gambit anyone having tutorial regarding this. or can any one help in other way i tried by making two faces in one column. lower part i define as a solid bed . but its not working because it showing some error in fluent after reading. thanks in advance. |
December 10, 2009, 03:00 |
YH Tan
Rep Power: 17 |
cannot understand ur question. Post ur sketches or geometry here.
Herntan, Add Reputation if I am right |
December 10, 2009, 07:41 |
Achyut Takalkar
Rep Power: 16 |
means i want to construct a solid bed in gambit. how could i do it?
i tried to define solids in fluent like( Adapt -Region) but in post processing at unsteady states, this is not giving bed expansion at even higher velocity of air. the fluid bed is showing static after 10 sec also. i got one tutorial of 2d mixing (Using the Eulerian Multiphase Model for Granular Flow) in that they defined solid bed in gambit. i am not able to understand how they did it. |
Display Modes | |
Gambit geometry problem | cestrin | FLUENT | 3 | July 4, 2012 03:33 |
[Commercial meshers] Problem with Mesh conversion Gambit msh Foam | Rachid BANNARI (Bannari) | OpenFOAM Meshing & Mesh Conversion | 25 | September 11, 2011 08:58 |
Gambit installation problem | Panos | FLUENT | 4 | March 5, 2009 23:44 |
Problem meshing with Gambit | Adrian | FLUENT | 8 | October 7, 2008 09:39 |
Startup Problem in Gambit 2.2 with WindowXP | Win Win Maw | FLUENT | 3 | January 25, 2006 12:09 |
