external flow with mach 3
Old   December 24, 2005, 08:06
Default external flow with mach 3
Roee
hello. can anyone tell me what turvollent modelling should i use in order to check the flow around a missle that flying in mach 3. i should be external flow, turbollence and steady, i know its sounds funny that it is steady but thats the way it should work. i also want to know if there is a way to check my mesh. Thanks ahead, Roee
Old   December 26, 2005, 15:43
Default Re: external flow with mach 3
Roee
Hi again. Can anyone help me? i need to know what turbulent model should i use in order to get the perfect results for compressed flow woth mach 3 around a missle. please try to help me. Thanks, Roee
Old   January 9, 2006, 08:12
Raj
Hi Roee,
Please Try with Spalart-Alamars Turbulent model...this is one equation and easily converge and also time taken is less compared to other models and you would get close to accurate result..
Raj
Boundaries in external flow crzbur FloEFD, FloWorks & FloTHERM 10 August 19, 2009 15:06
[Salome] Salome-OpenFOAM external flow (around a ship) tomislav_maric OpenFOAM Meshing & Mesh Conversion 34 August 13, 2009 09:30
problems in high speed external flow jon william FLUENT 2 January 14, 2007 06:37
Mach number and flow compressibility Guosheng Kang Main CFD Forum 5 October 26, 1999 15:56
