patch a small field in flow
Old   May 4, 2008, 11:46
Default patch a small field in flow
wu yu
I want to patch a small region in flow with high temperature 4000K(because I want to ignite the combustion),but I do not know how to do. patch is effected in a "zone" in FLUENT, I don't know if I can define a new "zone" in FLUENT. I tried to define a small zone in GAMBIT(this zone is surrounded by flow), however, when I export the mesh file, the boundary of the small "zone" are defined as "wall" automatically
Old   May 6, 2008, 08:27
Default Re: patch a small field in flow
Aris Nikolopoulos
From Fluent you go to for example iso-value and mark a region for exampe with Xmin<X<Xmax Then in the patch menu you will choose this region to patch.
Old   May 8, 2008, 10:47
wuyu
Thank you. now I can patch a temperature in a small point using a udf macro "define_adjust" or "define_initial" but for ignite the flow, it's not enough. we have to give a mass fraction of production for this point. I don't know how to do it.
Old   May 9, 2008, 07:28
Aris Nikolopoulos
Let me resay it. Because i was not clear. Go to Adapt->Region. Define Xmin-Xmax,Ymin-Ymax,Zmin-Zmax. And click Mark. This way you define a hexaedro in your field. Then go to Patch. Select the value you want to patch (for example gas temperature,or mass fraction of products) and then don't select fluid (from Zones to patch) but your hexaedron (from registers to patch). Patch will be applied only in your hexaedron.
Old   May 14, 2008, 14:05
wuyu
Thank you very mush. I got it
Old   April 9, 2014, 16:45
Default Hey Aris Nikolopoulos
José Branco
j.eduardo is on a distinguished road
I'm trying to ignite combustion too. I'm doing a region like you sugsted, and then patch with the value of temperature of 1500 k, but it is not working.
Any advice?
j.eduardo is offline   Reply With Quote
Given field does not correspond to patch david OpenFOAM Bugs 2 January 29, 2009 13:24
Gamma field on boundary patch tom OpenFOAM Post-Processing 0 March 23, 2008 06:56
Adding a field on patch in parallel jaswi OpenFOAM Running, Solving & CFD 6 February 2, 2008 13:18
Projection of field onto patch tehache OpenFOAM Running, Solving & CFD 0 May 7, 2007 02:24
How to specify a patch on a small hole allegro CFX 0 January 28, 2003 05:26
