January 3, 2006, 08:52 |
Gambit
How can I import a sine line-shaped into Gambit?
January 3, 2006, 13:13 |
Re: Gambit (Tip to draw 2D function curves)
function y=f(x) step1: using the function to get the values of n points. (you can determine the value of n) x1 y1 x2 y2 ...... xn yn step2: using notepad to write a data file. The pattern of the file is shown as follows. n 1 x1 y1 0 x2 y2 0 x3 y3 0 ...... xn yn 0
and then save the file filename.dat step3: start gambit main menu->file->input->ICEM input in the panel, find out the file filename.dat by Browse click on vertices,edges,face,net surface. and then accept. the curve is that one you want. Using the same method, you can draw 3D function curve and surface. Good luck! |
January 3, 2006, 13:16 |
x1 y1 x2 y2 ...... xn yn step2: using notepad to write a data file. The pattern of the file is shown as follows. n 1 x1 y1 0 x2 y2 0 x3 y3 0 ...... xn yn 0 and then save the file filename.dat step3: start gambit main menu->file->input->ICEM input in the panel, find out the file filename.dat by Browse click on vertices,edges,face,net surface. and then accept. the curve is that one you want. Using the same method, you can draw 3D function curve and surface. Good luck! |
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing | David-CFD | ANSYS Meshing & Geometry | 1 | April 1, 2011 05:22 |
Gambit help: Cube inside cube | Jack Martinez | FLUENT | 13 | August 11, 2010 06:29 |
Gambit 2.3.16, Xming or Exceed...HELP! | bambam3417 | FLUENT | 10 | May 7, 2010 12:39 |
Gambit -dev X11 doesn't work | Ervin Amet | FLUENT | 0 | October 28, 2007 08:33 |
3-D Mesh Check in Gambit..... | SHR | FLUENT | 4 | March 25, 2003 03:10 |
