script file for running fluent on linux cluster |
January 11, 2006, 08:27 |
I'm using the following script to run a single processor fluent job on a linux cluster machine using Sun Grid Engine:
#!/bin/bash #$ -S /bin/bash #$ -cwd export PATH=$PATH:/usr/global/Fluent.Inc/bin:$HOME export FLUENT_ARCH=lnx86_glibc22 export LM_LICENSE_FILE=7241@egr8-w2k export FLUENT_INC=/usr/global/Fluent.Inc /usr/global/Fluent.Inc/bin/fluent 3ddp -g -i run1.jou >& run1.out Batch jobs work fine on the main processor (linn1). However, when I use the above script to send to another processor on the cluster via Sun Grid Engine I get a directory path error. It appears that the other units of the cluster can't find the software. What should I do? Thanks for any and all help. Worth |
January 11, 2006, 08:45 |
Re: script file for running fluent on linux cluste
Hi, the command to run fluent on a cluster should be like: fluent 3ddp -g -pnet -i run1.jou >&run1.out& where -pnet is linked to the RSHD communications software. If you are using MPICH then you should use -pnmpi If you are using MPI/Pro then you should use -pvmpi
February 9, 2012, 11:31 |
i actually did try to run the same simulation i had ran on a windows environment on the clusters with the following command line
fluent 3ddp -t8 -cnf=/home/name/node -g -i pipe_sf.jou > result.out but got a lot of error messages. The /home/name/node is the file path name on my computer and the pipe_sf.jou has the script to read the case and data file with a number of iteration. My initial problem is that the case file did not even read to the end
joerik |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' | mfiandor | OpenFOAM Installation | 2 | January 25, 2010 09:50 |
OpenFOAM Install Script | ljsh | OpenFOAM Installation | 82 | October 12, 2009 11:47 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 06:51 |
Fluent on Linux Cluster | george | FLUENT | 0 | August 11, 2006 04:57 |
