Do virtual and real lines cause different results? |
January 12, 2006, 02:11 |
If we model a virtual line (virtual surface) in Gambit, the result will same as the real line (real surface) in Fluent? Thanks!
January 14, 2006, 12:58 |
Re: Do virtual and real lines cause different resu
Yes, indeed. Virtual geometry is only a tool used in Gambit to help user making complex geometries and, for example, to be able to have geometry "in the background"; I mean, if you merge 2 edges into one virtual edge, the original 2 edges will be send to the background. You don't see it, but if you delete that merged edge, you will see the original 2 edges again: they will come to the foreground again.
Hope this has been clear enough. Good luck! |
January 15, 2006, 08:28 |
Freeman Thank you very much for this short and concise explanation I have always avoided the use of the so called virtual geometry because I never understood why it was there Why not write an article about that point on the WIKI
[GAMBIT] Difference between real & virtual line, face, & volume?? | teguhtf | ANSYS Meshing & Geometry | 2 | October 5, 2009 07:47 |
virtual or real flow volume for wind tunnel? | qm | FLUENT | 1 | January 9, 2009 15:26 |
GAMBIT - VIrtual edges and Real face | Bridou | FLUENT | 1 | July 22, 2007 12:57 |
Convert Real edges to Virtual in Gambit | Freeman | FLUENT | 6 | October 24, 2005 15:14 |
Virtual entities to real entities | Lam | FLUENT | 2 | August 22, 2003 06:17 |
