XY plotting pressure coefficient on the wall
Old   January 16, 2006, 05:07
Default XY plotting pressure coefficient on the wall
Yucel Ozmen
Dear Fluent Users,
I solved the flow around the 2D obstance in Fluent. I used XY plot, Pressure, Pressure Coefficient to obtain distribution of pressure coefficient on the obstacle wall. But the values are overpredicted.I obtained -200 as pressure coefficient. it is not logical. What must I do to obtain logical pressure coef. (between -1<Cp<-2 ) Thanks
Old   January 16, 2006, 21:36
Default Re: XY plotting pressure coefficient on the wall
Anindya
Use proper reference values od area, velocity, etc in the reference values panel.
Anindya
Use proper reference values of area, velocity, etc in the reference values panel.
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
UDF to monitor minimum pressure on the wall Arvind Jayaprakash FLUENT 0 September 20, 2007 11:53
Does star cd takes reference pressure? monica Siemens 1 April 19, 2007 11:26
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 22:02
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
