Athlon 64 Gambit Compatibility?
Old   January 16, 2006, 13:20
Default Athlon 64 Gambit Compatibility?
Derick
Guys:
We have a AMD Athlon 64 PC running 32 bit Windows XP. We have successfully installed Gambit 2.2. WE have also successfully installed Exceed 6.1 3D. However, when trying to upgrade Exceed to version 6.2 as required to run Gambit in Windows, the setup program won't execute. Any attempt to run Gambit results in 'cannot load font' errors in Exceed's status window.
We have also successfully installed Gambit and Exceed 6.1 on Pentium 4 Machines, and the setup program to upgrade Exceed 6.1 to 6.2 runs fine. As a result, Gambit runs in Exceed 6.2 just fine on Pentium 4 machines.
Is there anything thatI am missing in the setup and/or upgrade process of Exceed on an AMD Athlon 64 with Windows XP (32 bit)? I feel like if I get Exceed to upgrade properly, Gambit will run fine.
Thanks in Advance,
Derick
Old   January 17, 2006, 03:31
Default Re: Athlon 64 Gambit Compatibility?
HVN
On the fluentusers web site, it is recommended to use exceed 9. For myself, I use actually exceed 7.
Old   January 17, 2006, 05:14
Makaveli
I have found no problems with running gambit on an Athlon 64 running 32bit windows xp under exceed 6.1 and have found no reason to upgrade to 6.2. Please note however that I am using Gambit 2.16 (I think)
Old   January 17, 2006, 17:28
Derick
Thanks guys..will look into it.
Regards
Gambit 2.3.16, Xming or Exceed...HELP! bambam3417 FLUENT 10 May 7, 2010 12:39
Gambit compatibility problem with VISTA armin FLUENT 10 February 19, 2008 21:01
Gambit -dev X11 doesn't work Ervin Amet FLUENT 0 October 28, 2007 08:33
Gambit OpenFoam compatibility Grid conversionquality ghanshyam OpenFOAM Pre-Processing 0 September 20, 2005 04:13
Gambit: versions compatibility alice FLUENT 2 January 31, 2001 08:27
