January 26, 2006, 16:39 |
UDF in batch processing
Does anyone know, once you compile and load a UDF into Fluent, do you have to load anything besides the case file when you're doing batch processing? Do I need to submit along with the case file the libudf folder that is automatically generated when I load a UDF, or do I submit the C file with which I made the UDF, or both?
I would appreciate your advice. Thanks! Tucker |
Display Modes | |
Running fluent with udf in batch mode | zonexo | Fluent UDF and Scheme Programming | 2 | March 10, 2012 07:50 |
[General] [Paraview] Batch processing and screenshots saves. | el douco | ParaView | 0 | April 9, 2008 03:37 |
problem with running UDF in batch mode | James | FLUENT | 0 | June 6, 2006 06:49 |
Help: Batch file for Parallel Processing ( 2CPU ) | SC | FLUENT | 1 | July 15, 2003 21:34 |
UDF in Batch | Prateep Chatterjee | FLUENT | 0 | August 9, 2000 11:01 |
