2D Couette/ Poisuelle Flow
Old   January 27, 2006, 19:17
Default 2D Couette/ Poisuelle Flow
CFD Guy
Hi.
EVERYTHING IN FLUENT
I am trying to model simple 2D Couette flow, but i couldn't ble to apply the zero pressure gradient ( when i give the top wall moving at 1 m/s; bottom wall stationary;left side as velocity inlet of 1m/s; right side as the outflow BC) I am getting a fullydeveloped flow profile like a parabola. Actually it should be a straight line with u(y=0) = 0 and u(y=ymax) = u_top.Can any one of you please help me.
My second Question is : I enabled low-pressure slip model and trying to run 2D coutte flow or 2D Poissule Flow with top and bottom wall with Slip BC. When i apply these the solution is converging in 1 iteration i dont know whats going wrong. But instead of applying the slip wall on both top and bottom, if i apply just for one its working fine. Can you please help me???
My last question: does any one of you have any Benchmark cases to verify slip modelsfor 2D couette and poissule flows. If some on have pls email me at dravimech@yahoo.com
Thanks CFD Student
Old   April 30, 2011, 09:48
Disabled
anon_d is on a distinguished road
I think you should use periodic B.C. to get the zero pressure gradient.
I've problem simulating the slip boundry condition too.
anon_d is offline   Reply With Quote
flow over a cylinder urgent! kevin FLUENT 8 August 11, 2015 13:00
[ICEM] Couette Flow kasman_meng ANSYS Meshing & Geometry 7 September 20, 2010 06:12
Simulation on Couette flow cheng Main CFD Forum 4 February 11, 2009 08:29
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 05:44
Couette Flow Vijay Patel Main CFD Forum 2 April 18, 2002 11:29
